really early WD6
C Clark
07-12-2004 00:14:25
I know of a wd6 serial number 546. All the books and information tell me that IH began their serial numbers at 501; and that all the 6-series were listed together. I looked at the engine number which was high and I am sure the motor is original (the early tractors had a single oil filter and a change over mechanism similar to the crawlers), the books tell me that the MD which had the same motor began in 1949 and the wd6 1950 so perhaps this explains the high number. Does anyone know when the first wd6 was produced? Could this be close to the first one?
Thanks.
C Clark
Justin
07-12-2004 05:55:25
 Re: really early WD6 in reply to C Clark, 07-12-2004 00:14:25
The first WD6 was chassis serial number 516. Do you know what the engine serial number is? it should be marked on a milled pad on the side of the engine.
C Clark
07-13-2004 03:20:07
 Re: Re: really early WD6 in reply to Justin, 07-12-2004 05:55:25
Thanks for the reply - Thats great to here
How did you find such information?????
(I'll see if i can get the engine number)
C Clark
C Clark *CORRECTION*
07-12-2004 01:50:52
affraid I got my dates mixed up (a decade late)
(CORECTION)...the same motor began in 1939 and The wd6 1940...
sorry
C Clark
David Manring
07-12-2004 05:14:26
 Re: Re: really early WD6 in reply to C Clark *CORRECTION*, 07-12-2004 01:50:52
I will guess at 1939 and one half they started the WD6. I have a 1941 in my back yard
Guy Fay
07-12-2004 05:47:43
 Re: Re: Re: really early WD6 in reply to David Manring, 07-12-2004 05:14:26
First MD wasn't built until 1941, suspect WD-6 is the same. THe IH Archives will be able to tell you the onth your tractor was built.
C Clark
07-13-2004 03:23:51
 Re: Re: Re: Re: really early WD6 in reply to Guy Fay, 07-12-2004 05:47:43
What are the 'IH Archieves' and how does one get access to them?
C Clark
