Farmall H steering
Joe J
07-12-2004 15:16:44
I have a 1945 Farmall H and the steering is very loose is there any quick or easy fixes for this or do I a lot of work on my hands
TomH
07-12-2004 16:36:28
 Re: Farmall H steering in reply to Joe J, 07-12-2004 15:16:44
While you have the steering box open you'll see a big castle nut. That stops the shaft when the steering wheel is turned in one direction. Then there's a big plug on the front of the steering box that stops the shaft in the other direction. Get someone to turn the steering wheel back and forth while you watch what happens there.
You can adjust both the nut and the plug to remove most of the slop. It's hard to describe, but once you look at it move you'll see how to adjust it.
Joe J
07-13-2004 18:27:52
 Re: Re: Farmall H steering in reply to TomH, 07-12-2004 16:36:28
Thanks alot guys yall been a BIG help
Farmallkid
07-12-2004 15:34:06
if you take of the grill, there is a casing that the steering shaft goes in to, if you take the top off of it, you will see a round gear, some are moon shaped, if its round, then take it out and turn it a 1\4- 1\2 a turn. That should take out the play in the steering. It only works with round ones. Other guys may have other tricks.
