stuck m
chris
07-12-2004 16:25:07
what works good to free up stuck pistons? my first thought was diesel or wd40?
Aaron
07-14-2004 06:02:41
 Re: stuck m in reply to chris, 07-12-2004 16:25:07
Pb blaster works great! If that and a hammer don't get it, soak the cylinder in pepsi or coke.
chris
07-12-2004 20:20:59
thanks for your advice, now i know what to expect.
John A.
07-12-2004 19:32:04
chris, Since you have the head off, and pan off too. Remove the rod caps, One at a time fill a cylinder with diesel about 1/3 full, set it on fire, let it burn itself out, it should free up and you are well on your way. The heat at the ring area is what breaks it loose after it moves a little soak it good with penetrating oil. Precausions and prep are allways needed make sure ALL flammable materials are well away from the tractor, Gas tank is off and away too. Also roll tractor outside if possible.
Hope this helps!
Later,
John A.
nebraska cowman
07-12-2004 18:26:43
Of all the "stuck" engines I've gotten loose over the years (I've lost count) Only one didn't require use of a hammer.
Jeff In Ontario
07-12-2004 17:55:54
I've often heard of a product called "PB Blaster" which many many people have had success with, might be worth a try.---Jeff
James
07-12-2004 20:12:39
 Re: Re: stuck m in reply to Jeff In Ontario, 07-12-2004 17:55:54
Jeff can you buy PB Blaster in canada? I might be able to send you some if you cant.
James in Texas
James Williams
07-12-2004 18:35:44
I totally agree with cowman,I just freed a 10-20 by using PB blaster worked great on 3 cylinders the 4th needed a hammer,maybe I didnt have enought paticents
