1946 farmall H mag
shank
07-13-2004 14:13:22
Found a broken rotor gear on mag.Replaced it & it still won`t start.Could it be out of time?If so,how do I time it?Put in new points.Have a new condenser,but don`t know how to install it.
Don`t have a book on it.Thank`s for any help,Shank.
Mag Man
07-14-2004 10:01:57
 Re: 1946 farmall H mag in reply to shank, 07-13-2004 14:13:22
Yes you have to time the gear Inside you will have a R and L on your rotor gear The gear inside that it meches with has a little tooth that is filled more than the others put it in between the R on the gear. JON
Dave_Id
07-13-2004 15:27:19
It's time to break down and buy a manual.
shank
07-13-2004 20:15:02
 Re: Re: 1946 farmall H mag in reply to Dave_Id, 07-13-2004 15:27:19
Thank`s for your help Dave.Maybe I can return the favor sometime.
