Cutout relay on Gen?
Ben
07-13-2004 14:47:21
I have a 1948 C Farmall and I'm trying to rewire it. The generator I bought doesn't have a cutout relay on it and I can only find wiring diagrams that show the GEN/ relay together. Can I wire it without out one or what exactly is it so I can get one.
Bob M
07-14-2004 05:05:40
 Re: Cutout relay on Gen? in reply to Ben, 07-13-2004 14:47:21
Dan – A generator MUST have a regulator (or a cutout relay) in order for it to work. Without it the battery will very quickly discharge through the generator when the tractor is shut off.
However it doesn’t matter if the regulator is located directly on the generator or someplace else. All that’s required is the generator and regulator are wired correctly, and the regulator has a good ground.
You can get a regulator at your CIH dealer, NAPA, Tisco, thru various online vendors, etc. Price is $35 - $40 or so. Hope this helps…
