Difference between Farmall M and AM
Bundy Bear
07-14-2004 02:59:51
Can anyone help me with information on the difference between a Farmall M and an AM. They seem to be very similar. Thanks BB.
Redfan
07-14-2004 05:47:33
 Re: Difference between Farmall M and AM in reply to Bundy Bear, 07-14-2004 02:59:51
G'day Bundy. I'm tipping you come from up near Bundaberg or attend a lot of B & S Balls.
The AM Farmall was the Aussie built version of the US Farmall M. Identical in appearance but ways to differentiate is to check the electrics. All OZ tractors had Lucas Electrics and the yankee tractors had Delco gear. AM was also fitted with a cast iron sump whereas M's had a pressed metal sump. Regards, Redfan.
Russ
07-14-2004 16:39:14
 Re: Re: Difference between Farmall M and AM in reply to Redfan, 07-14-2004 05:47:33
Aussie M; In the motorcycle world, BSA and Triumph used Lucas Electrics. They were affectionately known as the Prince of Darkness.
Hopefully the design and manufacture in the Farmall AM things were not as demanding.
Good luck and hope you are not outstanding in your field due to Lucas Electrics.
riverbend
07-14-2004 13:34:19
Is that where they make that fine tasting rum ?
Redfan
07-14-2004 14:18:20
 Re: Re: Re: Difference between Farmall M and AM in reply to riverbend, 07-14-2004 13:34:19
Yep, and the manufacturer is a major sponsor of a lot of the Batchelor and Spinster Balls (hence B & S) that the young people attend.
They also use a big white polar bear in their advertising.
little john
07-14-2004 06:36:37
Thank you, Redfan. I learn something new every day!
Built in Australia, huh?
nebraska cowman
07-14-2004 04:24:57
I think maybe the farmall name was not used or export. maybe someone else will tell us more.
little john
07-14-2004 03:33:30
BB, as far as I know there never was a Farmall AM. Can you tell us more?
Manuel
07-15-2004 18:31:38
 Re: Re: Difference between Farmall M and AM in reply to little john, 07-14-2004 03:33:30
There was the AM from Aus & the BM from the UK.
The AW6 & the UK version also the A414 & B414.
Hope this helps Manuel
