'66 Series belly tanks
Merlin in Saint
07-14-2004 13:50:27
Hello! I went up to a tractor show in Penfield, Illinois this past weekend. I saw a beautiful 1468 there, no cab. The most interesting part about this tractor to me was the belly/saddle type fuel tank that it had. It appears to be a factory-type option. Were these in fact an option on the '66 Series machines? How common are they? I grew up in southeastern Minnesota, and never saw one there. It looks like a pretty nice option. Thanks in advance for your comments!
Merlin
Hugh MacKay
07-14-2004 21:21:57
 Re: '66 Series belly tanks in reply to Merlin in Saint Louis, 07-14-2004 13:50:27
Merlin: In actual use those tanks had two problems. Damage to tank if you got into too much mud, especially if mud contained rocks. The second problem was build up of material between tank and tractor chassis. (mud, straw, leaves, etc.) They were also in way of some tractor adjustment and servicing. They were however a factory option.
I knew of a 1066 with tank in front of grill, and had an electric pump for supplying main tank. It made for a lot of front end weight change. Another guy I know had a flat tank on top of cab. His biggest problem was leaks from vibration, and leaks of diesel fuel up there made for interesting visual under dusty conditions. I found 150 gal tank on back of pickup was the least troublesome, and it did service more than one tractor.
The only large tractors I've seen with good space for enough tank are the articulated tractors.
Alvin NE WI
07-14-2004 17:48:23
Got one of those on our 1206 need it quitwe often, hold about 30 gal.
