Super A engine
VAJerry
07-14-2004 14:06:00
Got a block from what I was told was a 100 for my tractor. Removed sleeves and had it boiled. Ordered new sleeves for a 100, They didn't fit, too big at the bottom. Took old sleeve to IH dealer and they measured the size from a 130. I thought these would be inter chanagable it appears not. am I going to have problems with my cam and crank from the super A?
Stan(VA).
07-14-2004 20:48:04
 Re: Super A engine in reply to VAJerry, 07-14-2004 14:06:00
We talked about this back in June, you might want to check this link. Hugh and I have gone over alot of details recently on the various flavors of C113 and C123 blocks; that might also be worth a search. Hope that helps.
Stan(VA).
parts man
07-14-2004 19:55:57
Jerry, the crank and cam should be OK,, they just had a couple of different sizes at the bottom of the sleeves for those blocks.
VAJerry thanks
07-14-2004 20:01:00
 Re: Re: Super A engine in reply to parts man, 07-14-2004 19:55:57
I noticed the top was the same size.
