diesel fuel line
Jim in ks.
07-14-2004 17:04:48
Help!!! I have a Super MTADiesel with a leakey fuel line that goes from the tank to the filter, have tried welding it but it still seeps. does anyone make new ones?
El Toro
07-15-2004 12:57:47
 Re: diesel fuel line in reply to Jim in ks., 07-14-2004 17:04:48
Hi Jim, You can buy low pressure hose from most Auto parts store that will withstand diesel fuel
or gasoline. It is very flexible and you can get
barbed type fittings that you just push on that match the fittings on your old fuel line. Aeroquip or Alemite are several manufacturers that make this hose and fittings. We used them for years on tanks and trucks for measuring fuel
consumption and for our pressure gauges. You can
cut the hose to fit your need. Good Luck, Hal
El Toro
07-15-2004 07:40:57
Hi Jim, How long and what fittings are on the old line? Have you tried any major automotive parts stores? We have a store that will make hydraulic and fuel lines. Also refrigerant lines too. Hal
BULLDOG
07-15-2004 09:33:06
 Re: Re: diesel fuel line in reply to El Toro, 07-15-2004 07:40:57
I PURCHASED A CHEAP DOUBLE FLARE TOOL AND SOME SOFT COPPER TUBE TO MAKE MY OWN ON MY MD. THIS DOUBLE FLARE IS SIMILAR TO WHAT IS USED ON BRAKE LINE AND MATCHED THE FITTINGS ON MY TRACTOR.
El Toro
07-15-2004 10:43:20
 Re: Re: Re: diesel fuel line in reply to BULLDOG, 07-15-2004 09:33:06
Hi Mr Bulldog, That is what I use, a double flaring tool for steel lines or copper lines. I also can make flexible lines that use 5/16" flared tube fittings to pipe threads. These are not inverted flared as used on brake lines. Less chance to cross thread. Hal
jim in ks.
07-15-2004 19:29:58
 Re: Re: Re: Re: diesel fuel line in reply to El Toro, 07-15-2004 10:43:20
Thanks for some interesting ideas,just thought it would be nice to keep it orignal.
