Ever heard 0f 560 Short Turn Kit??
Wayne from Iowa
07-15-2004 05:45:33
I have a wide front 560 with a different setup on the steering. It has curved steering arms on the spindles, and the center steering arm has an attschment to it. I was told it was offered by IHC but cannot find it in parts book. This is the tractor I complain road wanders. Can anybody give me any insight of this??
Hugh MacKay
07-15-2004 18:27:51
 Re: Ever heard 0f 560 Short Turn Kit?? in reply to Wayne from Iowa, 07-15-2004 05:45:33
Wayne: Don't know what you have from the description. I had a 560 and 656 both factory wide fronts. The only difference in the two front ends is 656 has a longer center steering control arm that causes it to turn shorter. I know if you put that long center control arm on an SM without power steering it steers harder. There is a possibility 560 power steering may not have the same power as a 656. I never bothered changing my 560 to find out. By then most of my farming was done by 3 other tractors. 560 was silo blower tractor, didn't much matter how it steered.
Chris Brown
07-15-2004 20:47:45
 Re: Re: Ever heard 0f 560 Short Turn Kit?? in reply to Hugh MacKay, 07-15-2004 18:27:51
The short turn kit has curved down arms on the steering nuckles. And on the center steering arm ,theyre's a piece that bolts on where the tie rods originally hooked up,it spaces them out to where they are about a foot apart,and gives an exaggerated turn. I have never gotten to use it,The wide front came with the tractor and I haven't installed it yet.
42FarmallH
07-15-2004 07:34:27
I've seen a couple of them custom made in my day too. I have a semi-custom set up like that on my H w/Schwartz wide front. Friend of mine has full custom short turn setup on his 504 w/Schwartz. Turn about as short as with a narrow front...
Chris Brown
07-15-2004 06:20:14
Yup I heard of one, I've got one on my 560.
