International 10 20
Randy Jesse
07-15-2004 10:46:50
Have a International 10 20 that I want to restore. Hope to find a picture or to find out what the colors were. Was told it is a 1924, it has rubber tires. Any info will be greatly appreciated. Randy
Randy Jesse
07-22-2004 08:52:38
 Re: International 10 20 in reply to Randy Jesse, 07-15-2004 10:46:50
Thanks a lot to those that answered my question, the picture is great. I'm sure I will have many more questions before I am done. It is good to know that I can get such a quick response. Thanks again, Randy
Greg
07-21-2004 13:59:56
Randy,
The paint codes that I've found posted for the 10-20 is Dupont 27625 for gray and 7410 for red. You can determine the year built by checking the serial number against the 'Serial Numbers' list under Research & Info on the left hand side of the page. The serial number is on a plate on the firewall. If the plate is missing the engine number is usually the same or close. The engine number is on a raised area of the block, left hand side, just below the head on cylinder one.
Good luck.
El Toro
07-15-2004 12:44:25
Hi Randy, I saw a 10-20 for sale in the Lancaster
PA Farm Journal for $3000.00. I think it was on rubber. We had a 10-20 when I was a teenager and
it was originally on steel, but was changed to rubber so we could run it on macadam roads. Very good belt tractor. Our neighbor had a 15-30 that he only used for belt work. Mostly used it on a threshing machine. There was a more powerful 22-36 that came out later. These tractors were a big improvement over the Fordson it replaced. Hard to start and kicked like a mule. !0-20's were made from 1923 til 1938. Then we went to Farmall's. Hal
scotty
07-15-2004 11:08:41
third party image
Randy here is a picture out of thr tractor photo archives on the side of this page.
scotty
