M serial number ??????
49 Cubber!
07-15-2004 16:20:26
Been on vacation all week and came across a M for sale.Always having my notepad with numbers in it I walked around it to check the serial number,no plate nor any holes for one.So i go around to chekc the engine number,found it easy enough but it was a plate that had FBKM-31902 stamped on it,not stamped on the enigne like normal.After looking at casting codes and with the engine number I concluded it was a 41.Now,with the owners permission I scaped around the area where the number plate normally would be and still found no hole but instead was stamped Q-31902 and after further investgation I found the same number stamped under the plate where the engine was,not on the plate which had FBKM-31902 on it.Any ideas what this Q means?
Guy Fay
07-15-2004 19:37:18
 Re: M serial number ?????? in reply to 49 Cubber!, 07-15-2004 16:20:26
Why don't you contact me directly? Sounds like you've found something.
little john
07-16-2004 05:07:51
 Re: Re: M serial number ?????? in reply to Guy Fay, 07-15-2004 19:37:18
If you come up with an answer, perhaps you could share it with us. I'd like to know the answer myself, just out of curiosity. Thank you.
smoknbs
07-15-2004 17:04:26
I remember an article in RP about the Super H and the pictures show a Q *** painted on the hood . this M could possibly a test tractor that escaped being bought back
