100 Axle shaft seals
J D Carter
07-15-2004 17:15:22
Axle shaft seals leaking after filling the final drives with oil. Rebuilding (bearings and seals) What is the proper way to install the replacement seal. This seal of course looks nothing like the leather seal that was original. Would it not be prudent to leave the felt under the new seal?
JD
Hugh MacKay
07-17-2004 15:09:07
 Re: 100 Axle shaft seals in reply to J D Carter, 07-15-2004 17:15:22
JD: Not sure I would mix the two. I remember trying something like this once, it backfired.
