350 Suction Strainer
Mark K.
07-15-2004 22:12:59
Hello,
I'm getting ready to pull the cover off the hyd. tank to clean the strainer and was wondering if the valves have to be removed from the side? My pump didn't make a lot of pressure and I hope this helps. Mark
dick
07-16-2004 08:37:32
 Re: 350 Suction Strainer in reply to Mark K., 07-15-2004 22:12:59
It appears from the way you asked the question that you're talking about a 350 Utility, not the Farmall. As Aces indicates, cleaning the strainer on the Farmall is apparently pretty easy, unfortunately it's not on the Utility.
On the 350U, the strainer hangs down below the level of the gasket surface dividing the reservoir, and it's really easy to damage if you don't remove the top part of the reservoir by lifting it STRAIGHT up, and have a good place to set it down. Having the heavy valves hanging off the right side unbalances the cover and makes it much more difficult to handle. It's not absolutely necessary to remove the valves, but it surely does increase the chances of doing the job without the strainer having a fatal heart attack. This is a good job to get somebody strong give you a hand with in any case. If I recall correctly a new strainer runs about $70-$80. Good luck.
Aces
07-16-2004 04:54:56
If you are talking about a 350 farmall you do not have to remove the valves the strainer is on the right side of the tank with 4 1/4" hex head cap screws remove them and pull the strainer out.
