Re: Farmall H presure plate question
Allan in NE
07-16-2004 10:36:08
Scott,
That pressure plate, along with a re-surfaced flywheel is the main 'heart' of that clutch.
Pressure plates most generally "look" good, but often aren't. I'd put in a new high quality pressure plate, clutch plate, grind the flywheel and use a new throw-out bearing. Check that pilot bearing while you are there too....
Do these things and she should last another 50 years.
My view,
Allan
