51 M heating up
nick
07-16-2004 13:21:44
I have a 51 M that I was using to cut hay with a 9' JD 1219 haybine. After about a half hour the temp gauge rose up between "RUN" and "HOT". I just put a new radiator in and 6 gallons of new coolant in. Is there a t-stat that might not be opening? I thought that the haybine was too much for for the M but it did the same thing when I was raking hay. Any help appreciated.
Wayne Swenson
07-17-2004 15:03:07
 Re: 51 M heating up in reply to nick, 07-16-2004 13:21:44
Have you tried blowing out the radiator core?
Remove the radiator shell (tinwork) and carefully blow from the engine side towards the front to get all the garbage out. you may find a lot of grease if the steering gearbox has leaked. This is general preventive maintenance for any working tractor.
I used to hang a burlap bag over the grill to help keep alfalfa leaves out of the radiator when stacking loose hay with a Farmhand F-10 loader.
Allan in NE
07-17-2004 13:51:40
Nick,
Most of 'em will run up on the high side of "Run" when pulling fairly hard.
Allan
James
07-17-2004 13:01:50
You said that you put in 6 gallons of coolant. Did you mix the coolant with water {50\50} mix. Straight coolant will make the engine over heat. Also if the carb is stopped up it can lean out the engine and over heat.
Mark B
07-17-2004 03:47:33
It could be possible that the tractor is somewhat out of time or may need the block flushed.
Will Sick
07-16-2004 22:33:42
Make sure the fan belt is tight and the radiator is free of dirt, chaff etc. Also make sure that the water pump shaft driver is okay.You might have a compression leak into the water jacket. A good load should make an M warm up ,but they don't overheat too easily.
CNKS
07-16-2004 17:58:39
Could be, but it is not unusual for these tractors to run on the high side of the run area when loaded, perhaps not with a rake. The thermostat is below the top radiator hose.
