H Making noise with clutch engaged
BB
07-16-2004 19:49:37
My H has a chatering noise when the clutch is pushed in while in neutral. The noise goes away when you release the clutch while in neutral. Would this be the throw out bearing making noise or the pilot bearing? The noise is coming from the clutch housing. Will it hurt to work the tractor like this? The clutch seems very strong while pulling. Thanks in advance for the input.
BB
Wayne Swenson
07-17-2004 14:56:44
 Re: H Making noise with clutch engaged in reply to BB, 07-16-2004 19:49:37
If the noise shows up just as you begin to press in the clutch pedal, it is a throwout bearing problem.
If the noise appears when the clutch is completely disengaged, I would suspect the pilot bearing.
Have you tried greasing them?
Pilot bearing lubes from under the housing; rotate the crankshaft so the single mark on the front pulley is in alignment with the timing indicator and look for the grease zerk in the 1" diameter hole under the flywheel. 1 or 2 shots of grease maximum.
Throwout bearing lubes from the clutch pivot shaft on the left side.
Bryce Andreasen (Magnum)
07-16-2004 21:18:41
I have an H i am trying to sell, but i would guess from experience, that it is the bearing in the center of the fly wheel that supports the center shaft when the pressure plate is not holding it in the center of the flywheel.
