A vers C wide front ends
charles
07-16-2004 20:29:42
What is the diffence between the spindles(knuckles), center steering arm and knuckle arms on As and Cs? I know the tie rods, center axle, and axle extensions are different.
BIG JOHN
07-17-2004 18:05:09
 Re: A vers C wide front ends in reply to charles, 07-16-2004 20:29:42
They are altogether different. The upright of the spindles of an A are 12" and a C is 13". The center steering arms have totally different mountings, the A is a clamp on shaft type and the C is a two bolt on type. You also have both new and old style type front ends, (ball and socket or tie rod end).
