H carb rebuild
ellson
07-17-2004 04:42:01
I'm rebuilding the carb on my H and the slot on the idle metering jet is gone Any ideas on how can I remove it to replace
Wayne Swenson
07-17-2004 14:50:10
 Re: H carb rebuild in reply to ellson, 07-17-2004 04:42:01
I drilled one out, bought a replacement jet at the local IH dealer($15 or so), went to a gunsmith to determine the correct thread tap size, bought a tap, re-threaded the hole and all was well again.
Take your time and use progressively larger drill bits to remove the old material.
I would suggest getting the new jet first to have a size reference.
