Farmall H Belt pulley seal
Rock
07-17-2004 08:42:00
I have an H that is leaking oil from around the side belt pulley shaft. I thought that replacing the oil seal would just be a matter of taking off the shaft endcap and pulling the shaft out. But it doesn't seem to be that easy. Nothing feels "stuck", but the shaft just won't come out. Is this shaft a solid shaft that is attached to the gear on the other side? And if so, how do you get this thing off? Please don't say I have to take the whole belt unit off!
What am I missing?
Thanks
Wayne Swenson
07-17-2004 14:41:50
 Re: Farmall H Belt pulley seal in reply to Rock, 07-17-2004 08:42:00
My 2 sons & I just re-did 2 gearcases for their belt pulleys on their "H"s". we had them on the bench but you can just remove the driven shaft on the tractor.
Remove three capscrews under the pulley mounting flange and the shaft, spacers, & bevel gear will all slide out with a bit of assistance.
Remove the cap screw on the end of the shaft and all the parts can be pulled off.
I was able to obtain replacement bearings at no cost by going to an electric motor rebuilding shop. If my memory is corect you need a 6210 & 6208 bearing for the drive shaft. Remove any shields so the bearing will now lube itself from the transmission oil. Thoroughly clean all old grease residue before installing the used bearing. Factory bearings run $50 or so for the big one so it can be an expensive affair to replace them. NAPA wanted $45 for the 6210 size.
I have a Case/IH dealer in town (Fergus Falls, MN) so otained the new seal, felt dust washer, and mounting gasket from them at a very reasonable cost.
Carefully clean the metal spacers and put a VERY light coating of silicone on them just before assembly. Don't mix up the cap screws from the drive gear cover with the shaft cover; they are longer (don't ask how I found out) and will not compress the spacers under the pulley flange.
mail me if you need more info.
Rock
07-18-2004 21:46:54
 Re: Re: Farmall H Belt pulley seal in reply to Wayne Swenson, 07-17-2004 14:41:50
I took the cap off of belt unit, but the shaft doesn't want to pull out. If the gear comes off with the shaft, then how would the gear slide out if there are oil seals and bearings and what not around the shaft? Isn't the gear larger in diameter then those parts it would have to slide through?
Thanks
Andy in ohio
07-17-2004 10:22:37
yes, you do have to remove the unit. 4 bolts and a little help and your good to go! Just dont drop it on your foot. Good luck!
