Help! Distributor getting oil up to the points
Mark B
07-17-2004 10:06:08
I have a SMTA that has a Delco Remy distibutor getting oil up to the points. Distributor sets up and down. I was told by someone that ther is an o ring inside but my IH dealer says there isn't and that the Behlen power steering seal is what is causing the problem. What should I try to do to correct the problem? I have it apart but I never seen any o ring. Thanks in advance for any replies.
another doug
07-20-2004 05:07:27
 Re: Help! Distributor getting oil up to the points in reply to Mark B, 07-17-2004 10:06:08
Our SMTA leaks oil into the disridutor cap too, it has no power steering , so it must be from the hydraulic pump seal. Update us on your findings, and how you fixed it... please!!! Thanks, Doug
the tractor vet
07-17-2004 11:03:21
the seal in the hdy. pump is the one that is leaking and forcing oil up the shaft . there is no o/ring or seal in the dist.
Mark B
07-17-2004 14:44:52
 Re: Re: Help! Distributor getting oil up to the po in reply to the tractor vet, 07-17-2004 11:03:21
Do you think it is in the Behlen pump or the in the IH hydraulic pump?
the tractor vet
07-18-2004 14:24:41
 Re: Re: Re: Help! Distributor getting oil up to th in reply to Mark B, 07-17-2004 14:44:52
Well the only way i have ever seen the dist mounted is on the I H hdy. pump and the seal starts seeping and it goes up the dist shaft but i can't see what you have on yours as somebody may have done something that i have never seen before.
Mark B
07-18-2004 14:51:08
 Re: Re: Re: Re: Help! Distributor getting oil up t in reply to the tractor vet, 07-18-2004 14:24:41
From the front of tractor it starts with the hydraulic pump then the Behlen pump and then the distributor housing. I have it off right now but not tore apart yet. Is there something to look for on the Behlen pump also? Is there something I can clean the pumps with without hurting them? 50 years of grime lays on the outside. Thanks again. Mark
the tractor vet
07-19-2004 18:13:05
 Re: Re: Re: Re: Re: Help! Distributor getting oil in reply to Mark B, 07-18-2004 14:51:08
Now that is a new one on me having two pumps back to back , so it has to be the seal in the belhen that is going bad and also the bushings and letting the shaft more more then it is suppose to . As far a cleaning them mineral spirits diesel fuel what ever and a good stiff brush and elbow grease.
Mark B
07-20-2004 04:03:34
 Re: Re: Re: Re: Re: Re: Help! Distributor getting in reply to the tractor vet, 07-19-2004 18:13:05
Thanks Tractor vet, I will get it cleaned up and gone through and will let you know what I find out. Hopefully it is a curable problem.
