serial number for 606
johann
07-17-2004 12:54:52
Help! I need to find the engine serial number for my 606 deisel so I can get a major overhaul kit. So far I have found the firing order cast on the block and something that looks like a clock on the lower part of the block with a hand pointing to 12. So far , no serial number. Where is it and what are my options if I can 't find any. The serviceman said there were 3 different kits, each one for certain serial numbers. Please help! Thanks
K.B.
07-17-2004 16:43:27
 Re: serial number for 606 in reply to johann, 07-17-2004 12:54:52
There should be a small flat area just to the rear of the oil filter base. There you will find "D-236", which is your engine model number, and the serial number. These are stamped very small, so if your engine is at all dirty or has been painted, they will be hard to find. You might want to clean up the small flat area with a wire brush.
john *.?-!.* cub owner
07-17-2004 16:36:16
Can't find info for 606, but it looks like most of that general type have the serial just above the injector pump.
