1947 Farmall A electrical issues
Ted
07-19-2004 07:38:28
On my 1947 Farmall A, I am experiencing a drain of 0.3 volts when I test between the positive terminal and the positive ground ground wire (when the cable is un-hooked and the voltage regulator wires are also un-hooked).
When the voltage regulator is connected, I show a full 8.3 volts drain between the same battery post and the cable (I installed an 8v battery). (lights off, etc).
I have replaced ALL the wiring since, and no solution. When I connect the battery cable to the battery, the switch area starts to smoke.
SO now I'm trying to trouble shoot the problem. 1) Does anyone have a wiring diagram for the light switch so I can test that with my multi-tester?
2) Could I have mutliple problems (also regulator issues or generator issues)?
Any help would be appreciated.
Pete
07-19-2004 15:01:16
 Re: 1947 Farmall A electrical issues in reply to Ted, 07-19-2004 07:38:28
More than one problem is a real posibility Unhook every thing and reconect each item one at a time checking for problems each step of the way.
David in UT
07-19-2004 12:56:28
Ted,
Hmmmm...sure sounds like you've got a short-to-ground in there somewhere...can you trace the burned wire to its source?
It's the light switch you're working on right (not the ignition switch)? When I did my C, I had to figure that out too -- I did it by using the continuity tester on my multimeter. By testing different pairs of connectors, I was able to figure out which one was what...but I sure can't remember now ;-). I've got a diagram at home I think -- when I get in tonight, I'll look it up for you.
- David
