Super C 1st gear jumps out under load
ELMER
07-19-2004 13:48:33
My Super C is jumping out of 1st gear under load (two bottom plow). Is it just worn gears or something else. Seems ok in other gears. Thanks, Elmer.
Aces
07-19-2004 16:10:35
 Re: Super C 1st gear jumps out under load in reply to ELMER, 07-19-2004 13:48:33
Elmer Could be that the fork is bent and not moving gear all the way in gear could be the end of the gear shift worn out and not shifting all the way in, could be the ball and spring detent.
Hugh MacKay
07-19-2004 16:03:47
Elmer: The offsets have detent balls with springs, I suspect the SC, 200, etc are same. My 130 was doing this while plowing under heavy load. With 130 it is an easy look and gears were fine. I installed detent balls and new springs on transmission shift rails, cured the problem.
I suggest you don't let it do that too long, every time it jump out it will wear gears more.
