Farmall tractor model?
Dave
07-19-2004 16:28:59
I have a farmall tractor and am trying to determine what model it is. It has a wide front, 38" rear tires, and the prefix DE after the numbers. Anybody know? Thanks
Dave
07-19-2004 19:15:28
 Re: Farmall tractor model? in reply to Dave, 07-19-2004 16:28:59
There are no letters before the numbers. The letters DE appear after the numbers on the floor plate, and engine block. I can't find any other identifying tags. Steering column goes thru the center of the hood.
49 Cubber!
07-20-2004 12:36:40
 Re: Re: Farmall tractor model? in reply to Dave, 07-19-2004 19:15:28
Dzave,look on the engine just below the #1 spark plug,there is a flat surface with numbers and letters in it,you may have to sctarch off some dirt and paint,but it should be there.If the letters are FBKM then its a M,FBHM its a H,post the numbers and we can get a year for ya'!
CNKS
07-19-2004 18:40:33
I think you are looking at a part number. D is 5000 ft altitude, E is 7000 ft altitude, can't have both. With 38 inch rears, it is probably an H or larger. Look on either the left or right side of the clutch housing for a metal tag, and as the other post says, look at the prefix. Or look at the tractor photos on this site.
The prefix before the num
07-19-2004 18:31:12
Hi
