560 power steering removal and reinstallation?????
Chris Brown
07-19-2004 19:51:32
I have a 560 that the steering sector seal was leaking and the splines stripped out.like an idiot ,I took the 4 bolts out that hold the p/s control valve on,thats when all the springs and doo hickeys all fell out. My big question is can I remove the front casting from the tractor without removing the radiator. Could'nt I support the radiator with a strap from above and slide the chunk out from under it? The book says to take the radiator out with it,but it looks like to me,that's a good way to damage the radiator. Any information on this will be greatly appreciated.
Thanks
Aces
07-20-2004 05:03:36
 Re: 560 power steering removal and reinstallation? in reply to Chris Brown, 07-19-2004 19:51:32
Chris the frame that holds radiator is the cover for the the power steering over the polster shaft, so I would say you have to remove the radiater and frame off the steering hausing.
Chris Brown
07-20-2004 06:21:28
 Re: Re: 560 power steering removal and reinstallat in reply to Aces, 07-20-2004 05:03:36
Thanks. I was afraid you would say that. That is this morning's project.
Aces
07-20-2004 10:14:27
 Re: Re: Re: 560 power steering removal and reinsta in reply to Chris Brown, 07-20-2004 06:21:28
Chris the 706 806 and newer had a seperate cover plate but 460 560 all one.
Chris Brown
07-20-2004 12:25:21
 Re: Re: Re: Re: 560 power steering removal and rei in reply to Aces, 07-20-2004 10:14:27
I discovered a little trick. I took all the bolts out that hold the front casting in and slid it out to the last 2 bolt holes and put the two bolts in the right side frame rail,then removed the left rail ,that left the whole front end hanging by 2, 5/8" bolts but that's plenty. And it exposed everything I needed to get at,and I didn't have to lift that 3oolb chunk of cast iron. .
