Anybody mow with an H?
Eric Allen
07-19-2004 22:22:40
What kind of mowers are out there for an H without 3 pt hitch? Do they make sickles for them, or some kind of belly mounted or tow behind bush hog maybe? Just wondering what to look for, wanting to get into field mowing for hire. Thanks
NMfarmboy
07-20-2004 17:56:15
 Re: Anybody mow with an H? in reply to Eric Allen, 07-19-2004 22:22:40
We used JD #5 sickle mower for years on Super C cutting alfalfa. Worked great, but live PTO would have been nice.
jed
07-20-2004 06:26:26
In addition to sickle bar and brush hog mowers , you can get a cut conditioner. An over-riding clutch on the PTO is a good idea though. I pull a 7 foot New Idea Cut-Conditioner and my H handles that. It is a rotary flail basically.
Randy in NE
07-20-2004 04:14:51
As a kid we mowed some with an H and a 7' sickle mower. You can also pull a 5' or 6' bush hog type of mower. If you are wanting to get into mowing for hire I would look for something with live pto on it. If you use a bush hog type mower you will want to get an overrun clutch to put on the mower. Without live pto you maybe spending a fair amount of time waiting for the mower to quit moving so that you can change gears or put it in gear. The sickle mower isn't bad but the rotary type mowers can spin several minutes before you can get it in gear. With both types of these mowers you will need to back up and get a head start on the mowing so that they are up to speed when you run into the grass/hay/weeds. Just my $0.02 worth.
