IH 574 brake bleeder valve location
Matt
07-20-2004 03:45:49
I have a International 574 and recently overalled engine and now I have no brakes. I assume they need bled but can't find location of valves, anyone know?
Jim E.
07-20-2004 03:56:08
 Re: IH 574 brake bleeder valve location in reply to Matt, 07-20-2004 03:45:49
They are on top of axle housings. There is a bleeding procedure. You need manual, or some good instructions.
Bernard le mécano
07-20-2004 10:20:36
 Re: Re: IH 574 brake bleeder valve location in reply to Jim E., 07-20-2004 03:56:08
Hi, to bleed brakes, place small hose on the, open, bleeder valves, run those hose in the hole where you put HY-Tran oil, remove the fender on the speed transmission(1 2 3 4), pinch the 3/8 hose in front of the transmission cover with Vise-Grip, this is the return flow from the brake. Run the engine at 1500 rpm for ten min. you may have small oil flow from the hose, to allow the air to escape or when you see no bubble, then close the bleeder and remove the Vise-Grip. Check for firm pedal. Bernard le mécano Québec Canada
