Farmall H coil 6 volt/ 12 volt difference?
Farm w/Junk
07-20-2004 05:20:57
Hi my tractor was running on 12 volts last summer and my coil went out so i put a 12 volt coil on it. It ran good and started nicely. Now that I have switched it back to 6 volt it starts hard but runs good if you get it started. Would the 12 volt coil not work as good as it should with 6 volts? What is the difference? Its from OEM tractor parts and looks like the original but is 12 volt. Should I order a new coil? Thanks
Matt
Pete
07-20-2004 14:20:53
 Re: Farmall H coil 6 volt/ 12 volt difference? in reply to Farm w/Junk, 07-20-2004 05:20:57
Use the right coil AND condenser it is always
the best option.
rustyfarmall
07-20-2004 07:13:02
I assume that the 12 volt coil you have uses an internal resistor? If so, then by running a six volt system, you would be getting only three volts, so you would want to get a new coil. On the other hand, if the 12 volt system used an external resistor for the coil, then all you need to do is remove that resistor.
Allan in NE
07-20-2004 07:30:14
 Re: Re: Farmall H coil 6 volt/ 12 volt difference? in reply to rustyfarmall, 07-20-2004 07:13:02
And,
Reverse the coil's polarity if you went back to a positive ground.
That plug firing backwards could make it a little hard to start....but would probably run pretty good after she pops off.
Allan
Jed
07-20-2004 06:22:44
The 12 volt coil doesn't know any difference. If you put 6 volts across it , it will perform quite well. A coil is simply a winding. If you run a 12 volt system, simply add a chrysler resistor on the hot wire to the coil. They sell for about $3 to $5 at any autoparts. All they do
is reduce the voltage by 50%.
K-Mo
07-20-2004 10:12:38
 Re: Re: Farmall H coil 6 volt/ 12 volt difference? in reply to Jed, 07-20-2004 06:22:44
The coil won't care too much but the spark plugs will. For example, if a 12 volt coil with 12 volts applied supplies 30,000 volts to the spark plugs then applying 6 volts to the 12 volt coil will supply 15,000 to the plugs. Your right, to use a resistor with a 6 volt coil in a 12 volt system. Back in the late '50s and proir to electronic ignitions, a lot of the 12 volt systems by-passed a resistor during starting and then placed the resistor in the circuit after starting, there by giving a hotter spark for good starting.
K-Mo
