Mccormick 10 20 Orchard??
tony
07-20-2004 08:41:53
I was trying to find out how a 10 20 orchard tractor would be equipped I have a 10 20 that has a shorter steering column, seat, shift, lever and air cleaner it is also equipped with a PTO in the rear would this be what the parts books refer to as a California orchard?? Thanks for any replies Tony
Mike Androvich
07-20-2004 14:33:38
 Re: Mccormick 10 20 Orchard?? in reply to tony, 07-20-2004 08:41:53
I have a California Orchard 10-20, and the most characteristic thing about them is the lack of a belt pulley. Not just the pulley, but there is no way to install one. The casting over the clutch housing is completely different. It is smooth. The shorter steering column, etc. is typical of all the later orchards. California Orchards also have a different transmission, but that is not so easy to tell from the outside. Any more questions, just ask!
tony
07-20-2004 17:56:14
 Re: Re: Mccormick 10 20 Orchard?? in reply to Mike Androvich, 07-20-2004 14:33:38
Thanks Mike I'm thinking I must have a standard orchard model with PTO as this tractor has the belt pulley identical to standard 10 20's
Mike Androvich
07-20-2004 19:59:46
 Re: Re: Re: Mccormick 10 20 Orchard?? in reply to tony, 07-20-2004 17:56:14
I agree with you! It is very likely one of several orchard versions that IH made. There are at least 5 or 6 different types including narrow treads, low seats, Florida types, etc. They are quite fun to collect!
