Over Run Clutch Type and Cost
JBlav
07-20-2004 13:04:34
What is the best type (brand name) of over run clutch to get for a 53 Super C? Are there different styles? If so which is the best and why? And how much should I expect to pay? Thanks in advance.
Brian Schmidt
07-21-2004 08:58:47
 Re: Over Run Clutch Type and Cost in reply to JBlav, 07-20-2004 13:04:34
Watch eBay if you are not in a hurry. I have seen them go for $20 brand new on there.
Brian
Doug MO
07-20-2004 18:49:02
I just wanted to add that you need to grease the overrun clutch when you grease the tractor. There should be two grease fittings on it. Doug.
Tom W
07-20-2004 17:00:07
There are two types of overrun couplers. One is 1 1/8 by 1 3/8 and the other is 1 3/8 by 1 3/8. All the Farmall after 1943 use the 1 3/8 by 1 3/8. you can get them at a tractor store for from $55 to about $80. I got mine 2 years ago at the IH dealer for $55, They are a must for bush hogging if you don't have live PTO.
