Leaking gas
BT Jack
07-20-2004 13:29:40
My A leaks constantly from the carb, even with the shut off valve closed. Is there any other gas route to the carb or is the valve just faulty?
rustyfarmall
07-20-2004 13:57:02
 Re: Leaking gas in reply to BT Jack, 07-20-2004 13:29:40
The only way for gas to get to the carb is through the sediment bowl, which has the shut off valve in it. If I was you, I would rebuild the carb AND replace the sediment bowl assembly.
Jeff In Ontario
07-20-2004 13:34:18
I had this same problem 2 wks ago., it was a stuck float which overfilled the carb & leaked. My advice is to do what I ended up doing which is to rebuild the carb. ---Jeff
Greg-N-CA
07-21-2004 05:48:16
 Re: Re: Leaking gas in reply to Jeff In Ontario, 07-20-2004 13:34:18
I had the same problem on my B, I replace the sediment bowl assembly and rebuilt the carb. This combination solved the problem. Now about the timing cover seal..... ...
