Help with Dwell Angle
JON From NY
07-20-2004 17:48:09
I am trying to set the dwell on my 53 SM and cant quite figure it out I looked in the arcives and found a post that said 60 degrees dwell for a 4 cyl. I cant seem to get anything that low . The average reading I get is 76. Is there a certain RPM to check this at ? As I increase the RPMs it goes down then. Do I open or close the points to get down to 60? JON
Dave in CT
07-21-2004 08:38:19
 Re: Help with Dwell Angle in reply to JON From NY, 07-20-2004 17:48:09
If your dwell reading is too high, your points are too far closed; if your dwell is too low, your points gap is too wide.
CNKS
07-20-2004 18:09:10
Set the points at 0.020 on the high side of the cam, and the dwell will be ok. These are not exactly high performance engines.
