tractor storage
DENNIS in
07-21-2004 04:37:49
do you think i need to cut a air vent of some kind in the top of my new metal shed? their is about a 4x4 space on each end that i was going to cover with fine wire. the corners are not air tight . no doors or windows will be put in until i return in a few years
Jim Becker
07-22-2004 06:58:08
 Re: tractor storage in reply to DENNIS in NC, 07-21-2004 04:37:49
Is the concrete floor new? It will give off water for a long time. When I built a building, it took a year before it quit raining inside with the right weather conditions. I would vent it in or near the roof if it is a new floor.
Maybe already mentioned, squirt a little oil in through each spark plug hole and give the engine a couple turns by hand.
DENNIS in NC
07-22-2004 09:00:58
 Re: Re: tractor storage in reply to Jim Becker, 07-22-2004 06:58:08
thanks for the info the floor is 10 yrs old, on top of NC red clay it was my sons basketball court 25x25
Dennis E. Kearney
07-22-2004 04:26:47
thanks for all the info guys i forgot to block them all
Fred Milner
07-21-2004 17:05:50
It would be nice if you had someone that would go and turn the motors over a few time 2 or 3 times a year. That would help a lot to keep them from sticking. I have an F-30 that sat for several years but was turned several time a year and I got it running with just a little work. Might save you a lot of work in the long run. Blocking the clutch so it will not stick is a good thing to do. Cut a block of wood to hold the pedal down just a little.
DENNIS in NC
07-21-2004 14:03:29
going to portland ,the wife got a job offer that we could'nt turn down [ uncle] she said that if i quit my job and went i would not have to work . so i took her a month ago , long drive i will join her when my boss finds a replacement and i get all packed . . any retired military out their looking for a job? its listed in the armytimes ect lake lure nc or asheville local papers ect place to live boat pets welcome send land line ill call you
bob
07-25-2004 17:52:08
 Re: Re: tractor storage in reply to DENNIS in NC, 07-21-2004 14:03:29
am retired navy. send me a job application and will try it. thanks, bob...
DENNIS in NC
07-25-2004 18:40:25
 Re: Re: Re: tractor storage in reply to bob, 07-25-2004 17:52:08
send res to me i will forward
DENNIS in NC
07-25-2004 18:38:53
49 Cubber!
07-21-2004 12:13:42
I think what youre doing to the building will be fine.You didnt mention it but make sure you havre fresh oil in the crankcase and overfill it some.Also check the tranny fluid for water and overfill it too.I dont mean by gallons just enough to allow for the little leaks that may or may not occur. I agree with blocking the clutches.
Jimmy
07-21-2004 12:01:22
You need to block all the clutches.
Dakota Jim
07-21-2004 12:50:22
 Re: Re: tractor storage in reply to Jimmy, 07-21-2004 12:01:22
What would be the reason for that?
DENNIS in NC
07-21-2004 09:11:01
six farmalls on concrete floor, i will be gone 7 yrs if i close both ends it will make it that much harder for anyone to know what is inside- gas out, up on blocks , plugs oiled, batteries out, carbs drained , topped off with antifreeze, no tarps ,5 bags of charcole to help keep it dry, ( we used it while i was in the army-it works) covered all stacks ect with glass jars. what did i forget????? ???
scotty
07-21-2004 10:52:38
 Re: Re: tractor storage in reply to DENNIS in NC, 07-21-2004 09:11:01
Dennis, Dont forget to take your picture album, 7 years away from your Farmalls will seem like an eternity without some visual aid. Sorry, I gotta ask were your goin? I hope were ever your goin that they are payin you well to be there!
scotty
lee
07-21-2004 08:46:35
Where ya headed Dennis? That's a long time to be gone. No doors or windows? Can I assume the openings are there? Open up the corners at the roof a little more if not too much trouble. You could put in louvered corner vents. Don't cover your equipment with waterproof tarps that will sweat and rain on your stuff.
Steve W (NY)
07-21-2004 06:14:30
Dennis....what's the floor? There is no faster way to rust equipment than to put it in an airtight shed with a dirt floor. The condensation will rust it faster than if you left it outside. If it's concrete, you are OK, but if it's dirt, I'd vent it, and then cover the floor with plastic, then park your equipment on top of that.
Take Care
Steve
