Farmall H clutch disk question
SCOTT IN MO
07-21-2004 15:23:27
Just got my new clutch from Case and was comparing it to my old one . One thing that is different is the new one does not have the thin cup like disk that goes to the inside of the fly wheel to protect the clutch from grease. is this really necessary. I'M trying to go back original. Thanks for any help. I want to be able to grease the pilot bearing.
Jeff
07-22-2004 10:02:05
 Re: Farmall H clutch disk question in reply to SCOTT IN MO, 07-21-2004 15:23:27
I beleive that the one i got for my H was the same way, without that metal sheild thing. it was also solid all the way around where the one i took out had cuts in it i think every 90 degrees. with mine, you grease the pilot bearing through the flywheel. the bearing has one side covered so that keeps grease from getting out where the clutch is.
