706 VS 756
GS
07-21-2004 19:48:15
Are there any real major differences between the 706 gas and 756 gas tractors. I thought they were both the same other than model number. Just checkin----THANKS
GS
07-22-2004 15:49:55
 Re: 706 VS 756 in reply to GS, 07-21-2004 19:48:15
thanks for the info
K.B.
07-21-2004 20:32:55
Early 706's had the C-263 gas engine or the D-282 glowplug diesel. Later 706's had the C-291 gas or the D-310 German diesel, same engines as 756. The main difference between the two tractors is the shifting. 756 has a much improved shift linkage/ shift pattern. If I had to choose between a 706 and a 756, I would take the 756, for that reason alone.
Jimmy King
07-22-2004 05:48:43
 Re: Re: 706 VS 756 in reply to K.B., 07-21-2004 20:32:55
The clutch and Brake peddles have a different curve in them I don't remember which way without going out and looking at mine ( I have both ), one you push more forward the other more down.
wolfy
07-21-2004 20:01:50
706 gas had the 263 cu in motor at about 72 hp. The 756 had the 291 cu in motor at about 75.6 hp. 756 had a more comfortable larger deck; most had hydraulic seat; had smoother shifting pattern-could shift from high range to reverse almost like a shuttle (or r to low); most 756's had the tilt steering wheel...
