300 Utility steering gear box
Randy
07-22-2004 09:21:15
The steering box on my 300U leaks like a sive.
My neighbor just picked up a 300U and I noticed that someone put a grease zerk fitting where the fill plug is. Is this Ok to fill the box wtth grease? I will be rebuilding the box someday. My neighbor says his steers real easy. I'll wait until I see what you guys think.
TDK
07-22-2004 18:08:11
 Re: 300 Utility steering gear box in reply to Randy, 07-22-2004 09:21:15
Filling it with grease from your gun will be OK temporarily, but the grease will eventually harden & it will also be slightly harder to steer. After rebuilding you can use STP or Lucas engine treatment. They're both less likely to leak.
