Farmall A... Adding lights
Matt
07-22-2004 14:35:18
I know I can add lights to aa farmall A, but where are they supposed to be, and where do I mount the switch?
Is this a simple circuit or are there transistors and switching transistors?
Thanx in advance!
NDS
07-22-2004 15:06:48
 Re: Farmall A... Adding lights in reply to Matt, 07-22-2004 14:35:18
Just behind grille at bottom you should have about 1/2 inch round hole on each side there should be set screw in top of hole. A rod fits in these holes and lights are mounted on end of rod. Do not remember where rear light mounted. Switch should be in box with voltage meter. No one had ever heard of transistor when As were made it is just simple switch.
Matt
07-22-2004 15:15:14
 Re: Re: Farmall A... Adding lights in reply to NDS, 07-22-2004 15:06:48
Do I need to put in a new wiring harness, or is this an easy add?
Paul in Mich
07-22-2004 21:26:35
 Re: Re: Re: Farmall A... Adding lights in reply to Matt, 07-22-2004 15:15:14
Matt, you can buy just the lighting harness by itself without replacing the entire wiring system.
