M brakes question
Tom lW
07-22-2004 16:18:21
I have a servicemans guide but when my son moved he packed it up and we can;t find it. I am getting ready to put new brakes on a 49 M and wanted to know if there were any tricks or problems I needed to know. Thanks
Tom W
07-23-2004 06:43:00
 Re: M brakes question in reply to Tom lW, 07-22-2004 16:18:21
Thanks a lot for the posts. It sounds easy enough
CNKS
07-22-2004 18:15:46
Not much to it, just be sure you remember how they come apart. There is a bolt in the bottom of the cover, loosen it before removing the bands. Install the bands and turn it in as far as it will go, then back it off 1/4-1/2 turn. Adjust the pedals so clearance is about 1 1/2 inches from the pedal to the transmission cover.
rustyfarmall
07-22-2004 18:26:06
 Re: Re: M brakes question in reply to CNKS, 07-22-2004 18:15:46
That bolt in the bottom of the cover sometimes falls out. Yours may or may not have it, it is supposed to be there, but will probably function OK without it.
CNKS
07-22-2004 18:59:24
 Re: Re: Re: M brakes question in reply to rustyfarmall, 07-22-2004 18:26:06
Will work without it, band makes better contact with it there, though.
rustyfarmall
07-23-2004 04:58:22
 Re: Re: Re: Re: M brakes question in reply to CNKS, 07-22-2004 18:59:24
I agree 100%, if it's gone, it should be replaced.
