have Question on farmall M and on a IH 544
Jeremy
07-22-2004 16:56:33
on my farmall M it starts and runs wide open what could be the problem???? on the 544 It starts fine but after a little bit you need to pull the choke out for it to run I put a new intake gasket on it because i thought it was getting to much air but it still does it. any help would be great.
CNKS
07-22-2004 18:00:05
 Re: have Question on farmall M and on a IH 544 in reply to Jeremy, 07-22-2004 16:56:33
On your M it is probably the carb to governor connection in the tube between the two. The rod from the governor must fit in the slot on the carb throttle shaft. Otherwise your governor is hung up in the wide open position for some reason. The 544 sounds like it needs the carb cleaned and rebuilt.
