Radiator Shutter for A
David A
07-22-2004 19:07:12
I'm thinking of trying to add shutters to my Super A for better temperature control. I have no idea what they look like or how they mount.
Can someone point me to a photo?
Thanks David
Paul in Mich
07-22-2004 21:22:46
 Re: Radiator Shutter for A in reply to David A, 07-22-2004 19:07:12
David, The A parts manual shows an illustration of the shutters and closing linkage. It is a wise investment regardless of whether you plan to install shutters or not. I'm questioning your percieved need for shutters, unless you are restoring a distilate or kerosene model. If you are adding shutters for functional purposes as you stated to allow you "better" temperature control, I'm wondering what you consider "better". Gasolene models really dont need shutters, as they run on the cool side, and unless your radiator isnt corculating properly or you have lots and lots of rust built up in your block, your tractor should run just fine. Shutters wont help it run cooler, only hotter.
David A
07-24-2004 11:08:44
 Re: Re: Radiator Shutter for A in reply to Paul in Mich, 07-22-2004 21:22:46
Paul,
Thanks for your thoughtful followup. My Super A is a '53, just before factory installed waterpumps and thermostats. A previous owner appearently added a Farmall waterpump, a nice fitting unit. The problem is that the radiator gooseneck casting does not accomadate a thermostat so it tends to run cool. OK in the summer but in the winter I'd say the coolant feels about 100 to 120 degrees.
The real solution is to add a thermostat, but as I understand it, the 113 CI engine does accept the gooseneck that uses a thermostat. This is why I am considering shutters.
I will look in a manual. I've been getting by on a friend's 140 manuals. Time to buy the correct thing.
Maybe I should just forget about this and not worry about it.
Thanks,
David
Jim Becker
07-24-2004 13:46:40
 Re: Re: Re: Radiator Shutter for A in reply to David A, 07-24-2004 11:08:44
Since it was an incomplete installation, I would probably flush the coolng system out and take the water pump back off.
David A
07-24-2004 19:21:32
 Re: Re: Re: Re: Radiator Shutter for A in reply to Jim Becker, 07-24-2004 13:46:40
That's a good idea too. I'd need to keep an eye out for a stock lower coolant tube to replace the water pump with.
