Removing cam from Super C
Marv
07-22-2004 19:30:45
The cam gear stripped a few teeth on my 1951 Super C and I need to remove the cam to replace the gear. Looks like I have two options to get the cam out of the engine. (1) Turn the engine upside down to separate the lifters from the cam. (2) Find eight magnets with cables attached to slip down the push rod hole and separate the lifters from the cam. This should allow me to pull the cam. Both sound like a challenge. Any suggestions? Thanks, Marv
Josh
08-02-2004 05:21:21
 Re: Removing cam from Super C in reply to Marv, 07-22-2004 19:30:45
Your gonna have to take the radiator, crank pulley, and front cover off the engine to get the camshfat out anyway. If you go this far you might as well take the 6 bolts out required to split the tractor and turn it upside down.
Farmall Tim (NY)
07-26-2004 17:28:50
It's pretty easy to pull the motor on a C. I'd do it right and split the tractor. You may find that other things are not quite right once you start taking it apart. Where did those teeth go??
Chris Brown
07-22-2004 19:42:21
We had a 230 that I pulled the engine by myself. The engine is not all that heavy with the head off,I rolled the front away and grabbed the engine block and carried it to the workbench
(21 years old and still had a good back).It would have been an easy job for 2 people. Anyway you do it,I think it is going to have to be upside down to get the cam out and back in. It might be possible to get the cam out by turning it as it comes out and maybe poking the tappets up with something and it might be possible to get some real thick grease to hold them in for reinstalation,who knows. I'd do it upside down.
