farmall m rings
pedro
07-23-2004 06:22:54
wanted to fine out the corret gap on piston rings need to file down they are tight fit on sleeves no gap c248 farmall m engine need some help.
El Toro
07-24-2004 16:23:42
 Re: farmall m rings in reply to pedro, 07-23-2004 06:22:54
Hi Pedro, I received your note. I was glad to help you. The rings that you're going to file,
were they for a 3.875" bore? New standard size rings should have a ring gap close to .010"to.020". It sounds like your rings may be an oversize ring set. Do the new rings fit ok
in the piston grooves? They make a small grinder
for grinding the piston rings ends. Check with your local machine shop. Hal
El Toro
07-23-2004 19:25:37
Hi Pedro, Are these new sleeves and pistons that you're installing? There's a rule of thumb for determining ring gap. For every inch of piston
diameter you multiply by .003. On a Farmall M with a piston diameter of 3.875"X .003= .0116".
This is within the .010" to 020" limits stated in the IH manual.
I never knew where this rule came from, but it is very close to the clearances you need on your ring gaps. Good Luck, Hal
pedro
07-24-2004 14:01:45
 Re: Re: farmall m rings in reply to El Toro, 07-23-2004 19:25:37
thanks for your help this new rings i am stalling in used sleeves i order 4 sets didnt fit this set fit on pistons no gap on sleeves need to file them down to to fit right. thanks alot .tio97
El Toro
07-23-2004 16:39:34
Hi Pedro, According to my IH manual the ring gap should be between .010" to .020" for a Famall M. The manual listed the ring gap on all the Super M's And Super H's and then says all others.
I would double check with your IH dealer. Hope this is helpful. Hal
