Ignition switch or cable
daniel
07-23-2004 16:57:32
On my H My starter wont run when it is all hooked up. but if i take it off the tractor and bump it with jumper cables fromt he battery then it runs I have tight connections of the bsttery when it is on the tractor and hooked up. I put the test light on the chasis to the + on the battery and it shows power, from there to the switch(Hand press down on button to complete circuit to starter)sows power. WHen i press down on the switch nothing happens. I put the light on the other side of the switch and shows no power. So I took the wire off and power comes back. Should I replace the wire or the switch?
Sorry for the lengthy message!
Jeff In Ontario
07-23-2004 21:56:33
 Re: Ignition switch or cable in reply to daniel, 07-23-2004 16:57:32
I think you'd better replace both the switch and cables. It's not too expensive, and will save troubles down the road > Just my opinion! ---Jeff
nebraska cowman
07-23-2004 17:24:57
either a bad switch or a bad connection. What does it do when you short between the terminals with your plier?
daniel
07-23-2004 18:06:30
 Re: Re: Ignition switch or cable in reply to nebraska cowman, 07-23-2004 17:24:57
nothing
nebraska cowman
07-24-2004 04:36:26
 Re: Re: Re: Ignition switch or cable in reply to daniel, 07-23-2004 18:06:30
then it's not the switch
