560D air in inj pump solved
Chris Brown
07-23-2004 17:48:11
I have been fighting air in the fuel system for weeks,ever since I changed the fuel filters. I was sure it was something to do with the new filters(duh) it was not the stupid filters,I finally narrowed it down to the silly little primer pump,the rubber piston was letting air pass the piston. You guys don't know the hours of cussing I have spent on this, I have had the injector pump off twice now and over to the diesel shop,they keep telling me theres nothing wrong with it. I have changed the filter canisters and the steel lines from there to the tank,I have been through the water seperator several times also. You'd think I would have had the common sense to look at the simplest things first(like a leaking pump)yup a leaking primer pump,it would spurt a little diesel every time I pushed it ,and I never thought about it letting in air. Remember,always look at the simple things first,it might save you some hard work.
hagan
07-23-2004 19:20:18
 Re: 560D air in inj pump solved in reply to Chris Brown, 07-23-2004 17:48:11
Last winter I removed the fuel strainer from the tank due to it leaking and like you I installed new fuel filters and filled the tank with fuel but by gosh it would not start even after bleeding it at the pump. I finally tied the pickup onto the front of it and we pulled it nearly 1/4 mile before it fired. Once blead that was it has ran good since
