super m rearend
chris
07-23-2004 20:19:44
I have a 1939 M that has a crack below the axle housing, I have been told the reason for this is a bearing went out dropping the bull gear cracking the housing? a guy has a super M rearend-transmission for sale wants $100.00, (noise in transmission)? will this bolt up to the 39? thanks for any advice.
nebraska cowman
07-24-2004 05:46:13
 Re: super m rearend in reply to chris, 07-23-2004 20:19:44
a lot of them are broken by water in the housing. ice expands and it has to go somewhere. If your tranny is good otherwise it would be a lot easier to fix the crack.
chris
07-24-2004 19:07:05
 Re: Re: super m rearend in reply to nebraska cowman, 07-24-2004 05:46:13
I have 2 rusted bolts left to get out that holds the cover on over the rearend, then i can see what the problem is? if it was water that froze, what would be the best method of repairing this crack? thanks
bruce
07-25-2004 19:19:44
 Re: Re: Re: super m rearend in reply to chris, 07-24-2004 19:07:05
THE SUPER M REAR-END WILL BOLT-UP, BUT YOU WILL HAVE DISC BRAKES. YOU CAN NOT CHANGE THE BRAKES OUT. IT WILL ALSO HAVE A FASTER 4TH GEAR.
