wd-6 HAS A MISS SOMETIMES?????
jEFF
07-23-2004 20:42:20
WD-6 STARTS AND RUNS GOOD BUT HAS A DEFINITE MISS AT TIMES. HEAD , INJECTORS, AND PUMP HAVE ALL BEEN DONE SUPPOSEDLY. WHERE WOULD BE THE NEXT LOGICAL PLACE TO HUNT THE MISS.....
Geoff NY
07-24-2004 14:57:20
 Re: wd-6 HAS A MISS SOMETIMES????? in reply to jEFF, 07-23-2004 20:42:20
You might want to warm it up and check the valve gap clearances. If all that work has been done the head has been off and possibly the valves wern't checked after break in. Also pull the screen (filter) on the side of the primary pump and make sure it is clean. Good luck, Geoff
