140 rear 6 volt light
Mitch in NC
07-24-2004 06:54:28
Hey Farmall friends,
I busted the rear light lens and reflector on my 140. Can I salvage the parts from a H or M type tractor or would it need to be an offset?
Thanks,
Mitch
Jim in NC
07-24-2004 14:26:14
 Re: 140 rear 6 volt light in reply to Mitch in NC, 07-24-2004 06:54:28
You can get 6v sealed beams for your 140 from NAPA. By the way, I am from Colfax, near Greensboro.
Mitch in NC
07-24-2004 16:40:57
 Re: Re: 140 rear 6 volt light in reply to Jim in NC, 07-24-2004 14:26:14
Thanks Jim,
I'm from Pembroke, near Lumberton. I'll go to NAPA Monday. It took me a couple days to figure out it was a sealed beam. Got a piece of steel wrapped around my PTO shaft when I was bushhogging, and it splattered the light. But, luckily I found the retainer ring.
Mitch
Jim in NC
07-25-2004 09:51:01
 Re: Re: Re: 140 rear 6 volt light in reply to Mitch in NC, 07-24-2004 16:40:57
Sorry about your trouble. I will be passing near your neck of the woods hopefully this week. I am planning on going to Ocean Isle if I get caught up.
Mitch in NC
07-25-2004 12:45:03
 Re: Re: Re: Re: 140 rear 6 volt light in reply to Jim in NC, 07-25-2004 09:51:01
Cool. Holler when you go by on 74. I may hear you.
Jim Becker
07-24-2004 08:58:47
I believe all 140s came with sealed beam lights. If you have something with separate lens and reflector, it could be anything.
