Order Farmall Cub Parts Online
Adjust carb float on '47 Cub
Loren Acton
07-25-2004 10:50:39
I've just purchased a '47 Farmall Cub, serial #
10483, with an IHC carburetor. After installing
a carb kit, leakage and flooding has been cured.
However, the tractor still gives evidence of fuel
starvation and doesn't have much uumph. I
suspect that the carb float needs adjustment.
Can anyone tell me how to check for proper
float adjustment in this carb? Thanks.
lee
07-25-2004 12:35:04
 Re: Adjust carb float on '47 Cub in reply to Loren Acton, 07-25-2004 10:50:39
I usually just eyeball the bowl adjustment so use the link provided by bigdog. Suggest you also chec for good fuel delivery tank to carb if not already done so.
Bigdog
07-25-2004 12:22:05
Check out the link. Look at the float adjustment and fuel level procedures.
