Farmall Super C Gear Issue
Robert
07-25-2004 21:03:25
Was grading with Drag Blade got into to much gravel and stopped rig. When I released the load off a bit I could not go. I can get into gear but it is like it isnt catching. Only one side of the little shaft you can see on the brake housing is rotating. Have not cracked top off tranny yet any suggestions on what I may have broken??
Harold Hubbard
07-26-2004 05:17:24
 Re: Farmall Super C Gear Issue in reply to Robert , 07-25-2004 21:03:25
Sounds like you broke an axle, not uncommon with these tractors. Try holding first one brake and then the other, and see if it moves or tries to move while the brake is on. There are other problems that will give similar symptoms but a broken axle is the most likely.
You can look into the back of the transmission housing by taking the PTO housing off, but you will have to take the top cover off the transmission to fix it.
